pico first look sensor waveform
Crikeskank
Post by Crikeskank »
I have a renault scenic 1.6 with an annoying fault of intermittent power.
No fault codes,only fuel trims awry LtFT 14% positive with short term from -20 to +20.
I have just tracked down a used pico first look sensor and a 3223 pico scope capturing this waveform.
any body see anything amiss with an experienced eye
The engine was fully hot at idle
cheers
no2.psdata
(1.85 MiB) Downloaded 486 times
Re: pico first look sensor waveform
In the absence of + or - 20/25 STFT you would not have any LTFT
First and foremost, force it rich and then lean. Verify that that the O2 is good.
No profit / advantage in shooting the messenger.
EVAP - MAF - ECT - Unmeasured Air ..... ..... ..... .....
EAAD
Post by EAAD »
Crikeskank wrote:I have a renault scenic 1.6 with an annoying fault of intermittent power.
cheers
Hello
I assume that you have used the FLS in the exhaust tailpipe to capture the psdata file? It is a pulse sensor rather than a pressure transducer of which the pulses appear unremarkable, I note that there is nothing to sync from but no matter as all pulses appear relatively even, nothing of note
Self quote
other than tickover seems very low???
Edit: I didn't move my cursors from 720deg to 360deg, sorry but not particularly relevant given the above paragraph.
You describing intermittent power? but the capture was at idle.
You are on the right track by LT & STFT.
As has already been said in the post above start with test on the lambda sensors, that will give you more information/evidence and then think upstream, what would make this happen?
Also
What kind of intermittent power, revs load etc (does it run ok cold for instance)......year, mileage and any other info or tests carried out, engine code etc?
all the best
Good tools to have on board, the FLS has shown you that you have smooth running, equal contribution from all four cylinders, albeit with massive fuel adjustments made by the ECU.
It is adding an additional 20% in the short term and 14% in the longer term, it has detected a Lean Condition, which is absolutely brilliant as far as the Catalyst, Emissions and Smooth Running are concerned but it is trying to mask the fault and symptoms, not so good from a diagnostic point of view.
No fault codes
What scanner ?? And how often are you hitting the Clear Codes button ??
The upshot is that without those FT adjustments it would be running Lean.
Assuming your O2 is functioning correctly - That is your starting point !
ScannerDanner (Youtube) is big on fuel trims.
NB - I have measured idle at 770 RPM from your capture, you can compare that to the Specs for it.
