Maths Channels and Custom Probes - Top Tech 2015
PicoMike
Contact:
Post by PicoMike » Tue May 26, 2015 8:28 am
The files within this post are available to everyone, but are aimed at those who attended Top Tech Live! 2015.
Below are the various Maths Channels and Custom Probes Steve Smith mentioned within his seminar:
Maths Channels
MAF formula 1.8 litre 4 cylinder N-A Engine.psmaths
(346 Bytes) Downloaded 490 times
Inductive frequency measurement-Channel A.psmaths
(267 Bytes) Downloaded 423 times
Duty Cycle (Negative) -Channel A .psmaths
(266 Bytes) Downloaded 429 times
Digital frequency measurement-Channel A.psmaths
(279 Bytes) Downloaded 480 times
Custom Probes
MEMS 3 AXIS ACCELEROMETER.psprobe
(1.35 KiB) Downloaded 518 times
K100 milliamp clamp.psprobe
(3.47 KiB) Downloaded 543 times
Denso Diesel Fuel Rail Sensor.psprobe
(2.65 KiB) Downloaded 503 times
Delphi YDT272 Pressure transducer.psprobe
(3.71 KiB) Downloaded 503 times
Delphi Diesel Fuel Rail Sensor.psprobe
(1.38 KiB) Downloaded 505 times
DAF FR-GR Diesel fuel rail sensor.psprobe
(1.91 KiB) Downloaded 517 times
Bosch Diesel fuel rail sensor.psprobe
(1.34 KiB) Downloaded 534 times
Kind Regards,
Mike Valentine
Re: Maths Channels and Custom Probes - Top Tech 2015
Post by Fat Freddy » Thu May 28, 2015 9:08 am
Thanks Mike for putting these up. And Steve for putting them together.
Cheers
Darren Cotton
Post by Darren Cotton » Mon Sep 21, 2015 8:59 am
These are handy...
The Bosch FRP custom probe, do you know what Bosch system it is for??
Darren
Post by Steve Smith » Mon Sep 21, 2015 11:02 am
Hello Darren and thank you for the post.
The values used in the "look up" table were entered via a technical publication for min/max and then cross referenced through the entire pressure range using a vehicle with a matching fuel rail pressure sensor (to that of the publication)
From memory I believe the vehicle used was a 2003 Mercedes 220 CDI (No running faults present)
Post by Robski » Mon Sep 21, 2015 3:02 pm
check your emails Darren I've created one for your application :wink:
Darren Cotton
Post by Darren Cotton » Mon Sep 21, 2015 5:33 pm
Robski wrote:check your emails Darren I've created one for your application :wink:
Yes got that thanks that worked fine, seems that there are many variations, Steve that merc one didn't work correctly on my Bosch system today.... one Bosch FRPS will operate different to another Bosch sensor, i would say if your making a custom probe for this type of sensor your need to label it to vehicle, system and specific part number of the sensor.
Darren
Post by Steve Smith » Tue Sep 22, 2015 9:02 am
Thank you Darren for the heads up.
Would it be possible for you or Robski to share the new Custom Probe you have confirmed as OK for your vehicle?
