toyota 3.0L 1MZFE crank cam signal waveform
evanlip
Post by evanlip »
Hi,need some help here,does anyone have known good toyota 1MZFE 3.0L crank and cam waveform?coz i suspect a jumped teeth timing belt.
hope you guys can give me a hand here.
thank you..
Chris C Stahl
Re: toyota 3.0L 1MZFE crank cam signal waveform
Post by Chris C Stahl »
What year is this toyota?
evanlip
Post by evanlip »
hi,its year 1999,the model is Toyota Harrier in Japan,but many model uses the same engine,so i hope its the same.
Chris C Stahl
I have two engines for that year one is a vvt
evanlip
Post by evanlip »
HI,THANKS FOR THE SHARING,MINE IS VVT ENGINE,SO WHICH ONE SHOULD I REFER TO?
THE SECOND CAPTURE WITH GREEN COLOR?
DID YOU CONNECT TO ITS BOTH CAM SIGNAL AND THE CRANK SIGNAL?
Chris C Stahl
The green one is the vvt engine yellow is one cam, red is the second cam.green is for crank.
evanlip
Post by evanlip »
roger ,chris,thanx.....will hook up the scope tomorrow to check the waveform then..
thanx alot chris...
evanlip
Post by evanlip »
hi,chris,i have a capture of the signal.
is that not aligner?
it looks like a bit off from yours.
mcu15 cam crank bad.psdata
my capture
(1.79 MiB) Downloaded 718 times
