MAF Signal
s4c
MAF Signal
Post by s4c »
I have a Misti MAF signal which is in Htz. Can anyone tell me how to graph the signal so I can look for glitches?
Simon
Alan
Re: MAF Signal
Post by Alan »
Try this guide http://www.picoauto.com/tutorials/testi ... nsors.html
If that does not do the job let us know as there is now also an option in the software to plot frequency vs time that works on all of the scopes.
Alan
s4c
Re: MAF Signal
Post by s4c »
Thanks for the link. I have seen that one before.
Can you give me the info for mapping over time?
Simon
Alan
Re: MAF Signal
Post by Alan »
If you are capturing a new signal then I suggest you use the frequency option available in the PicoScope 4000 - select from the AC/DC drop down box.
If you have already captured the signal as a digital square wave then you can display as air flow using one of the maths channel options. From the tools menu you need maths channels, create then select advanced. I dont have a scope with me to show how to do this so for now please post your waveform as a .psdata file here and one of us will sort out an equation for you.
s4c
Re: MAF Signal
Post by s4c »
HI Alan
Please have a look at the attached post. If you could work it out it would be great. Also, if you could show me the workings for future ref that would also be great.
Simon
1996 4G93 TPS and AFM.psdata
(25.77 KiB) Downloaded 743 times
Re: MAF Signal
look in automotive presets it is in there.........
Re: MAF Signal
Your sample rate is way too low. X4 at least - avoid aliasing. You want a nice digital signal.
HTH
Re: MAF Signal
Fat Freddy wrote:Your sample rate is way too low. X4 at least - avoid aliasing. You want a nice digital signal.
HTH
agree at 300+µs iirc :shock:
Valhalla
Re: MAF Signal
Post by Valhalla »
Robski wrote:look in automotive presets it is in there.........
Where it states that the frequency option is available from 4000series Picoscope onwards. If you look at Simon's waveform again, the properties show his scope to be 3000series. That could be why Simon cannot find this.
Re: MAF Signal
I never opened the properties tab in this instance I measured the sample rate with the time cursors .......
