rover 25 p0722
Neilcur
Re: rover 25 p0722
Post by Neilcur »
Had another go at this the other day but car didn't falter but the buffer was only capturing a couple of pages then stopping i think it was 7 of 7 or something like that, is that to do with the way i have set the scope up?
Is the settings i have it on ok to capture the fault?
see attached trace below this was while the car was running ok
Thanks Neil
speedsensorgood.psdata
(337.93 KiB) Downloaded 458 times
Neilcur
Re: rover 25 p0722
Post by Neilcur »
I am running version 6.6.46.1. I took the car a run again yesterday for 30 miles and it didn't miss a beat but i changed some of the settings and it was capturing 65 frames of data so i just kept resetting it everytime it maxed it out and it was also better quality and didn't require much zooming in to see the data so thought that was a good setting.
Think i'm just going to have to keep road testing it with scope running until it falters and see what it captures
Thanks Neil
PicoMike
Re: rover 25 p0722
Post by PicoMike »
HI,
While I take a look at this, can you let me know what version of PicoScope 6 you are running (Help>About) ?
Thanks,
Mike Valentine
Online BDM: Pico Technology
choss38
Re: rover 25 p0722
Post by choss38 »
Hi Neil,
I've got the same problem with my Rover 25, will you tell me what it was at least ?
Thanks a lot.
Olivier
