Peugeot 307 misfire cold.
Re: Peugeot 307 misfire cold.
Won't do that again posting in 2 forums
You can post where you wish, just include all the same info & a list of parts fitted & tests done with results, this then saves dashing between forums to gather information to try & assist.
Again i would not be fitting another coil until there is proof that the existing one is u/s.
You could have tested the injectors in situ yourself :wink:
