- Pico Staff Member
PS7 Auto Early Access 7.0.101.11515 is ready for downloading and includes the following:
New features
Additional “Action” features
Following on from our previous posts above, we focus again on “Actions” where we now include the option to choose from a variety of sounds. Your chosen “Sound” will indicate the desired “Event” conditions have been met
• Please try these sounds and have fun with “Explosion” and “Siren”
• In addition to the existing “Actions” highlighted above in previous posts, we now have the option to “Run application”
• Selecting “Run application” will enable you to browse for the desired App you wish to run once the “Event” conditions have been met
Feedback on the design and function of the beta “Actions” feature would be most welcome
Bug fixes
• Improved stability of PS7 when navigating through multiple buffers
• Improvements to Linux installation on openSUSE
- Pico Staff Member
PS7 Auto Early Access 7.0.106.12177 is ready for downloading and includes the following:
New features
Additional security within “Action” features
Following on from our previous post surrounding the Run application “Action”, an additional level of security has been added.
• Above we have chosen to run Pico Diagnostics as our “Action” when the Event “Buffers full” occurs
• Note above how Enable external code execution must now be turned on to complete the “Action”
• Below, it is now possible to add additional arguments when using the Run application “Action”, for example: loading a file in the external application that has just been saved.
• Following on from the “Play sounds” action here viewtopic.php?p=103268#p103268 Custom sounds can now be used with the Play Sound action (.wav or .mp3 files).
Feedback on the design and function of the beta “Actions” feature would be most welcome. Click on More > Send Feedback within the software
New Reference Waveform Library (RWL)
Following on from Barneys forum post here viewtopic.php?p=103358#p103358 and article here https://www.picoauto.com/news/news-arti ... on-the-way we are proud to announce the arrival of the all new RWL
Benefits include:
• A user can now edit all metadata (Vehicle Details, Channel Labels & Notes) of their Reference Waveforms in the Waveform Library
• A user can now delete any of their Reference Waveforms from the Waveform Library
• Uploads now happen in the Waveform Library application, which means that PS7 is no longer blocked when a file is uploading.
• There is an upload queue in the Waveform Library application so users can see all the waveforms they've uploaded in the current session.
• Uploads will appear instantly in the Waveform Library, meaning there is no longer a 24-hour delay
• Log in sessions will now last for 90 days and won't be reset overnight
• General performance (speed of moving between pages, fetching data etc.) has been improved by up to x10
Feedback on the design and function of the new RWL feature would be most welcome
XY View now available
For those wishing to plot channels (input signals) against one another (e.g., plot channel A against channel B rather than against “Time”) we now have the XY View. For more information on the application of our XY view please see Ben’s forum post here topic22592.html to see why we have renamed this application the “Martins Method”
• Click on the “More” button in the left-hand tool panel and select “Views”
• Note: Clicking on the “Star” symbol to the left of the “Views” symbol will place the “Views” button in the left-hand tool panel where it will remain ready for use without having to select “More”
• Click on the “Views” button to reveal the Views tool panel and select XY as your additional view.
• Below we have opted for an XY viewport with the name XY 1, where channel A forms the X axis and channel B will be plotted accordingly (i.e., channel B will be plotted against channel A)
• Below is a typical example where XY view can be utilized to reveal the symmetry between 3 phase motor current with a phase shift of 120 degrees
• Above our XY 1 viewport plots channel C against channel B as summarised in the Views tool panel
Feedback on the design and function of the new XY View feature would be most welcome
Bug fixes (Early access versions 102, 103, 104, 105 & 106)
• Additional levels of security added when using the Run External Application option within the “Actions” feature (See above)
• Improved performance when capturing a large number of samples over slow time frames
• Measurement statistics now display data for all buffers when loading a file.
• Revised column and bit ordering of the FlexRay "Header" within a decoded FlexRay Frame.
• (Mac & Linux only) Saving to .csv now working with over 1000 waveforms
Math channels now appropriately accommodate regional variations for separators and decimal places.
• Improvements to “Action” notifications when setup is incorrect.
• The graphed channel now correctly updates ranges when viewing previous buffers or adjusting the probe.
• Resolved issue where the last buffer can sometimes appear with inaccurate data at the start of the waveform when a capture is stopped abruptly.
• Improvements to stability across all platforms
- Pico Staff Member
PS7 Auto Early Access 7.0.108.12447 is scheduled for downloading on the 13th September 2022
New features
Deep Measure BETA
Deep Measure provides a means to further analyse repetitive signals so as to reveal the intricacies of individual cyclic events when deeper (more detailed) analysis is required
The following forum post topic17711.html describes the operation and application of Deep Measure within PicoScope 6 which will eventually be replicated and improved upon in PicoScope 7
• Click on the “More” button in the left-hand tool panel and select “DeepMeasure”
• Note: Clicking on the “Star” symbol to the left of the “DeepMeasure” symbol will place the “DeepMeasure” button in the left-hand tool panel where it will remain ready for use without having to select “More”
• Given this is the first BETA iteration of “DeepMeasure”, confirmation of acceptance will be required to utilise this feature (See image below)
• Confirmation of acceptance of the BETA “DeepMeasure” (select “Yes”) will reveal the “DeepMeasure” control panel
• The “DeepMeasure” control panel allows the user to cycle this feature On/Off and Delete if required
• Here we can also “Name”, choose the relevant channel, specify Thresholds and Hysteresis values whilst also choosing to amend the “Rise/Fall Time Threshold” setting and “DeepMeasure” between Time rulers (See below)
• Below we have chosen to activate “DeepMeasure” on channel A and name the measurement “Crank Signal”
• Note how the Threshold and Hysteresis values have been set by PicoScope automatically with a Rise/Fall Time Threshold of 10/90 and “Between time rulers” is set to On
• As can be seen above, PicoScope has presented the “DeepMeasure” table for review by the user (Current buffer only) where each individual cycle of our signal (between the time rulers) has been analysed and the appropriate value displayed accordingly
• “DeepMeasure” data can be reviewed in 3rd party software such as Excel by clicking on the Export button within the decode table where the contents are exported in .csv format
• Below we have exported the “DeepMeasure” data above and graphed the Frequency of the signal using values displayed in column C
• Note the sudden drop in frequency of the line graph above denotes the rapid change in frequency attributed to the missing tooth of the crank pick up ring (one event between our time rulers)
• Please note, more features of “DeepMeasure” will follow in future PS7 updates
Feedback on the design and function of the beta “DeepMeasure” feature would be most welcome
Help
• Click on the “More” button in the left-hand tool panel and select “Help”
• Note: Clicking on the “Star” symbol to the left of the “Help” symbol will place the “Help” button in the left-hand tool panel where it will remain ready for use without having to select “More”
• Clicking on the “Help” button will now link users directly to our A to Z of PicoScope which can also be found here https://www.picoauto.com/library/picoscope-in-depth
Feedback on the design and function of the new “Help” feature would be most welcome
XY graph display at 1:1 aspect ratio
Further to the introduction of our XY View described here viewtopic.php?p=103445#p103445 the addition of XY view ports will now be displayed at 1:1 aspect ratio (square) by default. This will help with analysis of 3 phase motor current where equal X & Y axes are paramount when evaluating winding and rotor performance ( Please see Ben’s forum post here topic22592.html )
Below we have multiple X Y views of varying sizes but all retain their 1:1 aspect ratio for ease of analysis
Feedback on the design and function of the new XY viewport feature would be most welcome
Bug fixes (Early access versions 107 & 108)
Bug fixes
• Resolve data can stop capturing when using specific time-bases and sample rates.
• Resolve (Windows)GPUCache folder created occasionally when starting PS7.
• Changes to notes in Waveform Library do not appear when a file is loaded in PS7.
• Crank Math Channel sets SI prefixes to 'on' for RPM by default.
• Capture stops running after switching to spectrum mode.
• Crank math channel now functions with Reference waveforms
• Reference Waveform Library - Spelling error in 'ECU Make' drop down list.
• Measurements now present in the options panel when XY instrument is selected
• Default math channel colour updated when Dark mode selected (was black)
• Disable or adjust PS7 features relevant to XY view
• Reference Waveform Library - Custom values do not persist after editing a waveform.
• Reference Waveform Library - Javascript error when closing toolbox before it has fully loaded.
Thank you.
- Pico Staff Member
There are no immediate plans for Pico Diagnostics to be included for MAC
The focus at present is Guided Tests for Mac and then hopefully Pico Diagnostics
Could I ask, which feature of Pico Diagnostics are you most likely to use/require?
E.g. Battery test, NVH, Relative compression etc.
Take care.....Steve
- Pico Staff Member
New features
Deep Measure BETA
Following on from our introduction to Deep Measure for PicoScope 7 here viewtopic.php?p=103559#p103559 we have now included graph adornments to display cycle counts, threshold, and hysteresis settings
• Apply Deep measure as described in the link above
• In the example below we have applied 2 Deep Measure settings to Scope View 1 and 2
• Both apply to Channel A; however, Scope View 1 has Deep Measure applied to the entire waveform, whilst Scope View 2 has deep measure applied between the time rulers
• Note above the threshold setting at 3.2 V and hysteresis setting of 200 mV
• Below we can now see the graph adornments in Scope view 2 which display the cycle count and reveal the threshold (black horizontal line) and hysteresis settings denoted by the black vertical marker
Masks (Beta)
A huge thank you once again to the software teams who have delivered a beta version of “Masks” to PicoScope 7 Early Access
• Click on the “More” button in the left-hand tool panel and select “Masks”
• Note: Clicking on the “Star” symbol to the left of the “Mask” symbol will place the “Masks” button in the left-hand tool panel where it will remain ready for use without having to select “More”
• Given this is the first BETA iteration of “Masks”, confirmation of acceptance will be required to utilise this feature (See image below)
• Clicking on “Yes” in the confirmation dialog box above will open the Mask configuration window
• Here we can Import a Mask or choose the desired channel upon which to create a Mask
• Below we have opted to “Create mask from source” (using Channel A as our source) where the Mask is automatically created about the displayed signal
• Click on “Apply and close” to return to PicoScope 7 with the applied Mask
• Note below how the scope has captured 12 buffers without any Mask failures, denoted by the Mask measurement lozenge within the Measurement view panel
• Below we have several Mask failures (9 in total) highlighted within the Mask measurement lozenge, and denoted by a colour change within the Mask where our signal has intruded
• Note: Masks can be applied to any channel and Scope view
• Below we have added a Mask to Channel B, where the Mask measurement lozenges indicate a single Mask failure on Channel A only
• Masks can be hidden from view by using the “Views” button in the left-hand tool panel or by selecting “More” and “Views”
• Below we have opted to hide the Mask applied to Channel B within Scope view 3
• Now we have Masks, the perfect complement is to use “Actions” to alert the user when the Mask has failed or indeed passed.
• Below we have returned to a single Mask in a Single view on Channel A and selected “Actions” in the left-hand tool panel or, by selecting “More” and “Actions”
• With the Actions control panel open, select “Change event” where we have opted to choose “On Mask fail” as our “Event” condition
• With “On Mask fail” as our “Event” condition, we can proceed to choose an “Action”
• Below we have opted to “Stop capture” and “Play sound” where we have chosen the “Siren” option. Remember you can also play a sound file of your choice (.wav or mp3 formats)
• Below; after 365 successful Mask passes, our fault has occurred which is confirmed within the Mask Measurement lozenge (Failures 1) the capture has automatically stopped, and the siren has sounded to alert the user
• To edit the Mask, select the Mask Lozenge located below the Channel options to reveal the Mask tool panel
• Here the Mask originally created using the “Create mask from source” option can be turned On / Off or deleted and named accordingly
• In addition to the above, you can also click on the “Mask editor” to reopen the Mask configuration window where you can Export your Mask, or amend the X and Y axes of the existing Mask
Feedback on the design and function of the new “Masks” feature would be most welcome
Bug fixes
• Improvements to translation files
• Resolve stability issues when launching PS7
• Resolve stability issues with XY View
• Improvements to beta Masks interaction with Trigger, Time base and Sample controls
- Pico Staff Member
New features
CAN XL Decoder
In addition to the existing CAN decoders (which include Classic CAN, CAN FD, CAN J1939) we now have CAN XL
• Click on the “More” button in the left-hand tool panel and select “Serial decoding”
• Note: Clicking on the “Star” symbol to the left of the “Serial decoding” symbol will place the “Serial decoding” button in the left-hand tool panel where it will remain ready for use without having to select “More”
• The Serial decoding wizard will then open and present the Decoder dialog box (note below we can now choose CAN XL)
• Choosing CAN XL will then present the Serial decoding configuration dialog box where the “Data bit rates” are required for each protocol (CAN, CAN FD & CAN XL)
• Populate the bit rate fields as required and complete the serial decoder wizard
Below we have Classic CAN, CAN FD and CAN XL serial decoders within PicoScope (Displayed in Dark Mode)
Feedback on the design and function of the CAN XL Serial decoder feature would be most welcome
Masks (no longer beta)
Following on from the introduction to “Masks” here viewtopic.php?p=103629#p103629 we are proud to announce this is no longer in beta format and now “Stable”
• Masks can now be applied in Spectrum mode with Spectrum active
• To activate Spectrum mode, click on Instruments > Spectrum
Feedback on the design and function of “Masks” for Spectrum mode would be most welcome
PicoDiagnostics (NVH)
PicoDiagnostics version 1.16.79.0 is bundled with PicoScope 7 Automotive Early Access 7.0.113.13203 and includes the following new feature:
• RPM signal input via channel D will now allow for 0.5 pulses per revolution of the engine
• 0.5 Pulses per revolution will now allow for ignition events to be used as NVH RPM speed signals as they are triggered once for every 2 crankshaft revocations (excluding wasted spark) 1 / 2 = 0.5
In addition to the above, BNC+ scope users can now use the following BNC+ probes on channel D with NVH:
• BNC+ x1 Test Lead
• BNC+ x10 Scope probe
• BNC+ 60 A current clamp
• BNC+ Optical sensor
N.B The above probes utilizing standard BNC termination can also be used
Bug fixes
• Resolve stability issues when using Deep Measure
• Resolve failure to save bespoke colour schemes
• Improvements to performance of the graph view when Spectrum & Scope Masks are active
• Improvements to performance of Deep Measure Threshold and Hysteresis settings
• Improvements to the stability of the beta Mask feature (now stable)
• Improvements to interaction between Masks and Triggers
• Resolve Waveform Navigator failing to update
• Improve “Save” functionality when Mask is present in graph view
• Improve interaction between Masks and XY view
Second, can we get the rulers time stamp at the top or bottom at choice? Now it covers the phase rulers degrees.
- Pico Staff Member
Both of these suggestions have been logged with the software team
Could I ask about the Time Ruler handle request?
You mention they cover the Phase ruler degrees; the value of the current position of the time ruler includes both "Time" and "Degrees" within the ruler handle
Does this help or do you have a concern whereby the X axis "degree" graticule is obscured by the time ruler handles
Once again, thank you for the feedback and New Feature Requests
Take care.....Steve
- TwoWaves
I'm not able to send Bug Report or else with file attached from a Mac using Chrome
regards
