Astra j 1.7 diesel 2012
JOE TECH
Post by JOE TECH »
Hi got vauxhall astra J 2012 1.7 diesel not start .Fuel pressure ok cranking
Plenty off fuel injected into engine ( smoke from exhaust) cranking 200rpm
Egr valve removed no diffrence (exhaust not blocked)
Can anybody help with scope print of cam/crank to check if timing moved
No fault codes set :cry:
Re: Astra j 1.7 diesel 2012
Post your capture.
JOE TECH
Post by JOE TECH »
Hi thanks for reply,I did not save capture but printed it
If you could send a good example then I could compare it with my print
Thanks Joe
You could scan it and attach it. Waveform library is for automotive scope users only. You can’t just fish info, if you want help, onus is for you to post info not the other way around! And I don’t care with what scope you measured, this does not matter.
