Hi got vauxhall astra J 2012 1.7 diesel not start .Fuel pressure ok cranking
Plenty off fuel injected into engine ( smoke from exhaust) cranking 200rpm
Egr valve removed no diffrence (exhaust not blocked)
Can anybody help with scope print of cam/crank to check if timing moved
No fault codes set
You could scan it and attach it. Waveform library is for automotive scope users only. You can’t just fish info, if you want help, onus is for you to post info not the other way around! And I don’t care with what scope you measured, this does not matter.
