2004 Land Rover Discovery Crankshaft sensor code
GTautoElectrix55
Post by GTautoElectrix55 »
Hi we have got a this car in at the shop Keeps setting code p0335-92crankshaft sensor A circuit have resistance check sensor tests ok. Sensor has been changed and wiring looks ok. Have scoped Crank Cam and igniton coil 1.
Land Rover_Discovery_2004_20210510-0002.psdata
(16.8 MiB) Downloaded 252 times
Land Rover_Discovery_2004_20210510-0003.psdata
(9.35 MiB) Downloaded 244 times
Re: 2004 Land Rover Discovery Crankshaft sensor code
Have a look into waveform library if you can find something similar. To me, crank signal does not look ok, you have either a ring teeth problem, or space too big between sensor and wheel, or an aftermarket sensor.
ronw38
Post by ronw38 »
Just a thought, did you scope crank sensor at the sensor or the ECU the latter checks the complete circuit. Cheers Ron W
