peugeot 206 1.4 lambda back probed at connector and earthed at the battery but the amount of noise is ridiculous tried a couple of different earths and different croc clips?? ta very much
If all you're scoping is the O2 sensor then you can use it's own ground for a cleaner signal, I don't worry about much noise on an O2 & just add a filter.
