Renault trafic M9R Cam V Crank
wg-mot
Post by wg-mot » Wed Feb 12, 2014 9:49 am
Hi all
I'm wondering if anyone would have a good snapshot of cam v crank on a Renault trafic 2.0 ltr, I see there is already a request for the same on a Nissan primistar which will be the same. I took a suspect sample and noticed a couple of discrepancies although this may have been down to the battery getting low.
regards
craig
cam v crank.psdata
(158.18 KiB) Downloaded 457 times
PicoPhil
Re: Renault trafic M9R Cam V Crank
Post by PicoPhil » Mon Sep 14, 2015 10:38 am
Just looked on the waveform library and there is only a Battery current and voltage with Camshaft sensor under the engine code. If you saved a waveform can you add it, or send it to me and i will add.
Philip
