High ignition current ramp
Greg.H
Post by Greg.H » Fri Jan 24, 2014 5:58 pm
Hi everyone
2003 Seat 1.8T came to us with cylinder 1 misfire.This engine has 4 wire COP so transistor is inside the coil.i only had time to check the current and i was quite suprised when i've seen 18A for current.check the other 3 ignition coil they had 17-18A as well.We replaced the coil what fixed the misfire but i left with a question.
Why does it have 18A current?i've never seen high current like this.Aftermarket coils have different current but these were originals.
Coil 1 misfire.psdata
(6.32 MiB) Downloaded 422 times
PicoPhil
Re: High ignition current ramp
Post by PicoPhil » Fri Sep 11, 2015 12:01 pm
Have you looked on the waveform library to compare with any other VAG model.
Philip
mikehaimes
Post by mikehaimes » Mon Sep 28, 2015 11:22 am
That's pretty typical with VAG but I only see it on the GDI engine TSI FSI
tode
Post by tode » Tue Sep 29, 2015 7:25 pm
In those engines there is great difficulty of ignition, the spark serves to generate a lot of energy, because complex fluid dynamics and high pressures in the combustion chamber, also in this engine the sparks are two, the first shorter than the second, all this for avoid misfire and that the spark plug gets wet from gasoline. As mentioned by my colleague, even in the most modern engines of the Group Vag it happens equal, but also in the BMW engines.
Greetings
