I managed to find some information regarding voltage/pressure scale that are used on this engine 2AD-FTV. It's from a Toyota RAV4 model which uses the same engine as the Verso model.
Hello, if this is the right data probe for use with the pico.
To probe more precise data you need to check the pressure and voltage sensor with a scantool.
I hope okay.
Try to believe
Sorry this is a bit late and possibly now inappropriate given the time that has passed by. I have recently checked the fuel rail pressure of the current 1AD engine (2014) now fitted with a dual fuel rail pressure sensor, (2 in 1). I have attached a psdata file with some values and a little theory re testing this style of pressure sensor.
Take care.....Steve
Has anybody a pressure voltage relationship chart for a General Motors fuel tank pressure sensor in order to use it as custom probe for Picoscope to compare fuel drop every time one injector open up?
I already builded the probe as it needs five volts feed source which I take it from a 7805 standard voltage regulator.
It would be very useful to know what pressure it is inside or outside the fuel pressure regulator as fuel rail pressure rises and drops according injectors switching pattern. Here you are a pic from my Pico 4423.
As far as I know this sensor has an indirect voltage response to pressure increments, so for vacuum you can get about 4.5 volts and as pressure rises the voltage output drops down
