Vectra Z19DTH
Leigh16v
Vectra Z19DTH
Post by Leigh16v » Wed Dec 04, 2013 6:38 pm
I have a customer with a 2004, Vectra Z19DTH.
It's slow to start after standing for more than an Hour, and has recently started cutting out under load.
Fuel pressure fault sprung to mind!
Fault codes are to do with Fuel Pressure Regulation, upper limit Reached, which will be the cutting out under strain.
I'm not up to scratch on this type of fuel Regulation, as it has what seems to be a DRV on the :lol: back of the pump, as in most common rail engines, Then it also has one on the fuel rail, opposite end to the pressure sensor.
Upon cranking, it takes a while for the pressure to Hit the 200 bar mark.
On tickover I scoped both " Rail Regulator" and " Pump Regulator"
I'm sure the rail Regulator is ok, but unsure of the the " Pump Regulator", but am not sure, as I'm not sure exactly how this system works!
Here are the scope captures at Idle,
Any help or explanation into this system would be Appreciated... :)
Vectra Z19DTH Glyn.psdata
Pump regulator
(7.71 MiB) Downloaded 251 times
Vectra Z19DTH Glyn Rail.psdata
Rail Regulator
(7.9 MiB) Downloaded 217 times
Re: Vectra Z19DTH
Post by Robski » Wed Dec 04, 2013 10:22 pm
it would help for starters if you labelled your channels & how & where you were probed/grounded/testing, without, those captures are as mad as a bottle of chips !
Phoenix
Re: Vectra Z19DTH
Post by Phoenix » Fri Dec 06, 2013 8:51 pm
have you check the back leak on the injector, also check the end of the rail back leak pipe if you have fuel coming out when when cranking the reg U/S
