cant install pico 6 rolling back driver???
ecosse
Post by ecosse » Thu Sep 05, 2013 8:16 pm
hi ive a new lappy on windows 8 and when I try to install pico 6 the latest one, It loads all the way up to near the end then just starts rolling back and wont install, has anyone seen this before? :D
ecosse
Re: cant install pico 6 rolling back driver???
Post by ecosse » Thu Sep 05, 2013 8:35 pm
just realised that it actually makes the shortcut's on the desktop briefly and then roll's back.
I tried it on xp compatability but still nt working :(
Post by Martyn » Fri Sep 06, 2013 9:50 am
Is this 6.7.21, 6.7.28 the release candidate, or 6.8 the beta version ?
Can you post c:\windows\dpinst.log, or at least the relevant part of it.
ecosse
Post by ecosse » Fri Sep 06, 2013 8:29 pm
hi its the 6.7.21 though tried older versions 2 of them :D
here is my file attached
DPINST pico.txt
(138.59 KiB) Downloaded 344 times
ecosse
Post by ecosse » Fri Sep 06, 2013 9:42 pm
managed to get pico's Delphi software to load????
ecosse
Post by ecosse » Sun Sep 08, 2013 10:02 pm
ok so cant open lots of my files as they were taken with a newer version so still no further forward with it :D
surely :D someone can solve this one for me????
Post by Martyn » Wed Sep 11, 2013 9:52 am
I would suggest trying the Beta release version from here http://www.picoauto.com/download-software.html, look carefully for the words Beta Release in the middle of the screen and click on them. If it still rolls back it may be a windows permissions issue which will require some more detailed investigation
MAE
Post by MAE » Wed Nov 13, 2013 11:38 am
I'm getting the same fault, says rolling back then comes up that the install wizard was interrupted??
MAE
Post by MAE » Thu Nov 14, 2013 4:25 am
i have tried both beta and stable versions and get the same, puts desktop items on the desktop, then states in the install program "rolling back action" and the install progress bar goes in the wrong direction and removes the software and icons
gn8691
Post by gn8691 » Thu Nov 14, 2013 9:16 pm
I had this once and i seem to remember that i uninstalled the current version i was using then did a reboot.
After that i installed the newer version.
Not sure if its the same problem for you but might help someone.
