cant install pico 6 rolling back driver???
MAE
Re: cant install pico 6 rolling back driver???
Post by MAE » Fri Nov 15, 2013 2:47 am
brand new computer with windows 8, its never had a version of pico installed
Post by Martyn » Fri Nov 15, 2013 6:54 am
Can you go to c:\windows and send a copy of dpinst.log to support@picotech.com
MAE
Post by MAE » Fri Nov 15, 2013 9:40 am
file sent
MAE
Post by MAE » Fri Nov 15, 2013 10:45 pm
just an update on my problem, picoscope6 non automotive installed and operates fine but retried pico6 auto but still same problem
Post by Martyn » Fri Nov 15, 2013 10:50 pm
That's very unusual as they are the same underlying codebase, which versions of each have you tried?
MAE
Post by MAE » Sat Nov 16, 2013 9:13 am
both stable and beta
Post by Martyn » Sat Nov 16, 2013 12:02 pm
Which versions of the beta and stable releases ?
MAE
Post by MAE » Sat Nov 16, 2013 8:48 pm
latest ones, is there earlier versions on the site as i could not find them?
Hitesh
Post by Hitesh » Thu Nov 28, 2013 11:06 am
There is an installation log file that can be created which will provide some further information. However, these may contain information about your system. Could you please e-mail support@picotech.com with this file and we will assist you further.
The process to generate the file is as follows:
  • Open a command prompt window in Windows with Administrator Priviliges
  • use the cd command to change to the directory where the installation executable is e.g.
    Code: Select all
    cd C:\temp
  • Run the following command:
    Code: Select all
    PicoScope6Automotive_r6_7_40.exe /v"/L install.log"
If you are using the Beta software, please change the name of the exe.
Many thanks,
Hitesh
Technical Specialist
Pico Technology
