2.0 hdi rhy 2001
ecosse
2.0 hdi rhy 2001
Post by ecosse » Tue Jul 30, 2013 11:14 pm
looking for a known good for 2.0 hdi 307 2001 if anyones got one I would be gratefull, I will post one ive got and if anyone cares to take a look to see if its good that would be great :D
Kenny
rhy cam and crank.psdata
(38.44 KiB) Downloaded 368 times
Re: 2.0 hdi rhy 2001
Post by Robski » Wed Jul 31, 2013 6:47 am
Insufficient sample rate/sample interval, increase sample rate & take another capture.
Low sample rate = less dots drawn, what does it tell you in the properties tab ?????
arjen
Post by arjen » Thu Aug 01, 2013 4:48 pm
I have a RHY from my peugeot partner but the cam profile is not the same. I'll see tommorow if I have a known good signal for you.
What is the problem with the car? I see that the voltage and rpm's are a bit low. This can cause a non starting engine. Had a couple of these cars with a bad starter. Too low starting rpm's will lead to an engine that won't start.
ecosse
Post by ecosse » Thu Aug 01, 2013 7:03 pm
thanks arjen if you have a known good that will be great, think the bat was a bit low when I took this capture, I think the voltages may be low due to me not having the scope connected properly, I will hopefully get on it on sat and get some more testing done. :D
got another capture here if you want to take a look though still had the scope leads connected wrong with the earth(black) on one side of the crank sensor and the main(red) on the other :shock:
rhy pug cam crank high sample 2.psdata
(1.65 MiB) Downloaded 408 times
Darren Cotton
Post by Darren Cotton » Fri Aug 02, 2013 6:06 am
Kenny, are you sure bat voltage is good enough, this is not cranking fast enough... As Arjen asks what's the fault with the vehicle?
Are you chasing any fault codes? check voltage and starter......
Darren
arjen
Post by arjen » Sat Aug 03, 2013 11:08 am
I have a known good waveform, but somehow it will not upload.. I'll try uploading again later.
If you send me your email I can also mail you the waveform.
The timing in your waveform is not correct.
ecosse
Post by ecosse » Fri Aug 16, 2013 9:28 pm
hi guys just realised/remembered I had posted this here? the only codes were camshaft sensor codes I suspect a correlation code, and its showing no sync with cam/crank on diag, timing was checked and found good when pinned up and is still not showing as sync'd, its still in bits and my customer has a loan car for now and will prob not get back on it till a later date. but I will be back on it, also customer had said he was looking for a new car anyway and if he does get one I will be keeping this so I can figure it out cause its def got me on the run at the min :D
