2005 Mustang GT 4.6 V8
PicoMike
Post by PicoMike » Thu Jun 20, 2013 1:29 pm
Hi All,
Today at work we decided to capture some 2-wire COP Waveforms from my 2005 Mustang. It has no faults, these were purley taken for Waveform pre-sets.
We noticed that at idle we were seeing 3 lots of signal, however on rev, we only saw one?
Anyone know why? Only idea was that while idling the ECU is ensuring there is no unburnt fuel...??
I did the test on several plugs....result the same each time...
Mike Valentine
Re: 2005 Mustang GT 4.6 V8
Post by Robski » Thu Jun 20, 2013 2:47 pm
As you say Mike it will be to lower hydrocarbons @ idle, the multi striking will cease around 1200 RPM-ish .
Capture again with a longer time base & increase RPM (1µs sample interval) & use the time cursors where the multi striking ceases to give an idea of RPM 8)
PS Animated GIF's would have looked sweet :)
PicoMike
Post by PicoMike » Thu Jun 20, 2013 2:53 pm
Robski wrote:As you say Mike it will be to lower hydrocarbons @ idle, the multi striking will cease around 1200 RPM-ish .
Ah righto, cheers for confirming :)
Mike Valentine
PicoKev
Post by PicoKev » Thu Jun 20, 2013 4:52 pm
AuthorMike wrote: these were purley taken for Waveform pre-sets.
Come on Mike you were very clearly in St Neots not in the Croydon borough! :shock: :) :D :lol: :lol: :lol:
Sorry could not resist that one :P
As Robski says multi strike has been used in the US of A for some time as an element of emissions strategy at idle(ish), i have heard of some systems that maintain multi strike > 3K rpm, quite prevalent in racing engines, also a number of the specialist ECU manufacturers offer the function.
I am guessing that the Pico breakout leads did not fit then! :cry:
PicoMike
Post by PicoMike » Thu Jul 18, 2013 8:39 am
Just to confirm the thoughts on this, we re-ran the test and it appears that around 1700 rpm the signal changed to a single fire...
Confirmed this by longer time base and gradual increase in revs...
At 699.3 ms through to 806.4 ms you can see the reduction from 3 events to one.
Mustang_Test2.psdata
(617.93 KiB) Downloaded 295 times
Mike
Mike Valentine
Post by Robski » Thu Jul 18, 2013 5:39 pm
I placed the time cursors at the last multi-strike event & the first single strike event and this indicated 1200 RPM on the frequency/RPM info tab at the bottom right of the graticule 8)
Post by Fat Freddy » Thu Jul 18, 2013 11:17 pm
indicated 1200 RPM on the frequency/RPM -- ----- ---- --- --- - ---- -----.
The missing words will be "indicated 1200 RPM on the frequency/RPM so thats 2400 RPM for a four stroke"
Sorry. Couldn't help it. 8) 8) :D
Post by Robski » Fri Jul 19, 2013 5:34 am
hmmm I'll have to look at that again, might have confused myself ..........
Forgot to multiply for 720°, or to put the 2nd vertical cursor at 360°, not a fuel pump is it :?
blake
Post by blake » Fri Aug 23, 2013 11:27 pm
Hey Mike,
Where did you get the test leads that you are using between the ignition coil and the coil connector, or are those home-made? They look like a big time saver compared to peeling back insulation to get the amp probe around the wire.
Thanks,
Blake
PicoMike
Post by PicoMike » Tue Aug 27, 2013 2:35 pm
Hi Blake,
I believe it was a PP327 breakout lead - http://www.picoauto.com/breakout-lead.html
Can't remember which size exactly it was we used....
Cheers,
Mike
Mike Valentine
