Do I have conclusive evidence
Re: Do I have conclusive evidence
Post by KimAndersen » Mon Jun 24, 2013 12:34 pm
Hi Avdr
That sounds promising with the new throttle body actuator. It's odd that it doesn't matter whether there is a feed back signal to the ECU or not.
It is working and that is what counts. :wink:
Kim
Avdr
Post by Avdr » Mon Jul 22, 2013 7:15 pm
Just wanted to add a final follow up to this thread. The van is still working perfectly, I feel it safe to say fault cured by the new throttle body.
Thanks for all the input,
Andy
stuzx4r
Post by stuzx4r » Sun Mar 18, 2018 4:00 pm
Hi, you state that the new patch lead only uses 3 wires not 4, do the 3 used wires crossover between the plugs or could the 4th wire just be disconnected from the original loom plug?
Thanks.
