2006 Mazda 6 L3 2.3
s4c
2006 Mazda 6 L3 2.3
Post by s4c » Tue Jun 04, 2013 12:51 am
Can anyone help me with a good trace for a 2006 Mazda 6 L3 2.3 Cam and crank.
This on has the 3 wire hall effect sensors. I have quite a few traces with faulty timing chain but would like a trace of a known good.
Simon
modo
Re: 2006 Mazda 6 L3 2.3
Post by modo » Tue Jun 04, 2013 4:22 am
I have 2008 I think it's a 2.3 from memory the 2.0 and the 2.3 are the same.{ I hope} look at it and see what you think.
2008 6 CKP CAS Coil Control Injector #1.psdata
(2.48 MiB) Downloaded 306 times
s4c
Post by s4c » Tue Jun 04, 2013 8:27 pm
Thanks for that, but it seems a bit different from mine.
Would be happy to hear your thoughts.
Simon
Cam and Crank 003.psdata
(184.54 KiB) Downloaded 272 times
modo
Post by modo » Tue Jun 04, 2013 9:29 pm
I have Mazda 2's & 3's they are all different I can send them to you but I don't think they will help. :oops:
s4c
Post by s4c » Wed Jun 05, 2013 8:27 pm
If you could post them it would be great.
Simon
modo
Post by modo » Fri Jun 07, 2013 6:35 am
This is a 2005 Mazda 2 1.5lt
2005 Mazda2 1.5lt CAS CKP Coil Injector.psdata
(2.2 MiB) Downloaded 267 times
s4c
Post by s4c » Mon Jun 10, 2013 8:33 pm
Many thanks for that.
Simon
onboardtech333
Post by onboardtech333 » Thu Jun 20, 2013 10:35 pm
This should be the same as yours
Unfortunately pc is down so I cannot check your attachment till I'm back at work
s4c
Post by s4c » Fri Jun 21, 2013 8:08 am
Thanks for the waveform ,however , that one is from the 2 wire sensors, my one is the hall affect 3 wire.
Just to add, the one I posted is a known good.
Simon
Post by Robski » Fri Jun 21, 2013 10:34 am
OBT
Just wondering was that capture yours to share ? (IATN label)
