What you need right now is a good wiring diagram to diagnose this problem - you won't solve this problem by looking at a serial scanner - if you ask me.
With the starting point in P1613 which indicate there is no communication between the CIM and the engine control unit or the signal is distorted - you should try to measure the resistance in this wire or use your picoscope to see, if a signal is present.
Kim
