Opel/Vauxhall z1.6se
hbr
Post by hbr » Sat Mar 23, 2013 9:16 pm
Hello, is there someone who has a know good capture of the cam and crank signal from a Opel Astra z1.6se, year 2002.
Thanks in advance.
Re: Opel/Vauxhall z1.6se
Post by Robski » Sat Mar 23, 2013 10:44 pm
Liteace
Post by Liteace » Sat Mar 23, 2013 10:53 pm
Whats the problem with it ?
hbr
Post by hbr » Sun Mar 24, 2013 11:50 am
The car has a problem with the start. Sometimes it fires up at once and on the other time it has trouble and it seems that the engine is not sparking in the right moment because the engine seems to get stuck.
No trouble codes in the ecu. So i made a capture of cam and crank to see if the signals where good.
I did not have a known good but thought to check the timing. The timing marks on the pulleys where spot on, but my feeling sad something is wrong, so checked the tdc with the spark plug out and found the cam was one tooth of, strange because it did not set a fault code. Corrected the timing and made another capture, engine seemed to fire up at once but after a few times starting it struggled again. So I wanted to be sure to get a know good one.
Attach a view of the before and after capture, of cam and crank. The good one seems to be the same as the one Robski posted.
Opel z1.6se cam good.psdata
(4.55 MiB) Downloaded 289 times
Opel z1.6se cam wrong.psdata
(1.45 MiB) Downloaded 364 times
mteste03
Post by mteste03 » Sun Mar 24, 2013 5:40 pm
Hi.
Have you checked the key on timing gears?
Matt
hbr
Post by hbr » Mon Mar 25, 2013 9:58 pm
Hello made some meassurements tonight, found that the ecu fires one of the dis coils on the wrong moment during the start.
hbr
Post by hbr » Mon Mar 25, 2013 10:15 pm
Also notice the camshaft signal is strange during the start, made a capture of the camshaftsignal also and found that the 5v, signal and ground are to high during the start, after this its good until the alternator kicks in and goes charging then the 5v, signal and ground get pulled down under.
Somebody a clue?
hbr
Post by hbr » Wed Mar 27, 2013 9:03 pm
Checked the keys on the pulleys, they are good, also found that the negative battery terminal gives a problem so I shall replace this.
Also made a capture of the dis coil pack, at the start the amps at one of the two coils has a strange behaviour.
Amps dis coil.psdata
(4.69 MiB) Downloaded 268 times
