messed up relative compression wave form, what is wrong?
jarrod27
Post by jarrod27 » Wed Mar 13, 2013 4:49 am
what is going wrong here is it the settings, the scope, or the amp probe, it is all brand new on pre settings. Image
jarrod27
Re: messed up relative compression wave form, what is wrong?
Even with the filter on the wave form still has the long tails. thanks
Post by Alan » Wed Mar 13, 2013 5:13 am
That an interesting / odd waveform (which is a way of admitting I don't know the answer). Two possible guesses, the first is a loose connection from the clamp to the BNC connector on the PicoScope causing the signal to drop out - check turned / not loose. The second would be a loose connection on the vehicle - perhaps battery terminal.
Can you recapture but add channel B as battery voltage and then post again - I want to see if the battery voltage jumps up a bit when the current drops out. Best to post the screenshot as you have an the .psdata file for this one.
mapengo
Post by mapengo » Wed Mar 13, 2013 8:26 am
Try your scope in a different USB port Jarrod.
Doc...
MAE
Post by MAE » Wed May 01, 2013 7:27 am
I thought i would jump on this post(hope you dont mind) as i am experiancing a similar problem, just purchased a pico advanced auto kit, i get the same thing on a battery test or comp test, have the same issue in pico scope software even connected to a battery sitting on the floor totally away from a vehicle i get erratic waveform. I have tried differant laptops, test leads and software versions. only thing i haven't subtitued is the pico(for obvious reasons). Does the pico team have any advice on this? i have been in contact with my supplier in australia and they currently dont have an answer
Lee
Post by Lee » Wed May 01, 2013 12:29 pm
Is your laptop plugged into mains, could be noise through charging system within laptop.
Have you tried with laptop not plugged into mains?
Kind Regards
Lee - LMH Engineering Services :D
MAE
Post by MAE » Wed May 01, 2013 12:40 pm
Tried plug and unplugged. No difference
Post by Martyn » Thu May 02, 2013 7:18 am
Does it happen on any of the channels, or just one ?
Which software version are you running ? Help->About to Cut and Paste the Text
MAE
Post by MAE » Thu May 02, 2013 10:17 am
Haven't tried channel 3 or 4 yet but defiantly both 1 and 2
I tried the current version as of Tuesday last week and the earliest available version on the web page
Post by Martyn » Thu May 02, 2013 10:32 am
and are you using the supplied blue USB cable directly between the scope and the laptop ?
