Does PicoScope 2204 work with PicoScope Automotive 6?
stuvx
Post by stuvx » Sun Feb 10, 2013 1:49 am
I just bought a used PicoScope 2204 and am wondering if this model is supposed to work with the PicoScope Automotive 6 software.
I can get it to work fine with regular PicoScope 6 software but no luck with the automotive version of the software. The automotive software doesn't recognize my PicoScope 2204.
My Picoscope 2204 is labelled 'automotive oscilloscope' on the case, if that makes any difference.
Thanks for any help.
Lee
Re: Does PicoScope 2204 work with PicoScope Automotive 6?
Post by Lee » Sun Feb 10, 2013 12:53 pm
The 2204 is a 8-Bit, Test and Measurement Scope and is not designed or intended for use with Automotive applications.
As far as im aware there is no 'Automotive Version' of this scope as its a really poor scope to use with Automotive.
It will NOT work with PicoScope Automotive Software or the Pico Diagnostics software.
If you read this thread all the points ive highlighted will be relevant to this scope aswell.
http://www.picoauto.com/support/topic9561.html
Hope this helps
Kind Regards
Lee :)
Post by Martyn » Mon Feb 11, 2013 7:16 am
Can you post a picture of the scope and case, sounds like someone has just put a 2204 in an automotive case. Were there any accessories with the scope ?
