2003 Renault Clio 1.4 K4J711
tomd
Post by tomd » Thu Jan 24, 2013 11:11 am
Help
I have the above vehicle in my workshop. Non start.No fault codes stored. Corroded plug on crankshaft senor.Replaced sensor and plug with modified version from Renault.Still no start checked crank sensor with scope have a good pattern pretty much the same as the one in the pico libary but only approx.half the max voltage i.e 1volt max as opposed to almost 2volts shown on the libary picture.The switch rate is pretty much the same. Is this normal Renault or is this popssibly the problem?
antthecat
Re: 2003 Renault Clio 1.4 K4J711
Post by antthecat » Thu Jan 24, 2013 11:55 pm
What's the cranking speed in live data.
Not being rude but has it got the basics fuel spark and compression?
Ant
Liteace
Post by Liteace » Fri Jan 25, 2013 8:07 am
Hows the immo lamp when cranking, Ive had quite a few of these with immo\key problems
ScannerDanner
Post by ScannerDanner » Sat Jan 26, 2013 6:32 pm
what type of crank sensor is it?
VRS or Hall Effect
Post by Robski » Sat Jan 26, 2013 7:31 pm
ScannerDanner wrote:what type of crank sensor is it?
VRS or Hall Effect
VRS Paul off the top of my head.
OP a picture or the PSD file wouldn't go a miss ........
ScannerDanner
Post by ScannerDanner » Sat Jan 26, 2013 10:45 pm
VRS or Hall Effect
Thanks Robski
OP I don't mind a 1 volt peak on a VRS during cranking. But with this type of sensor you can have a good signal at the sensor and still have no signal at the PCM. Depending of course how you connected your scope and where you measured the signal from.
