Hyundai Santa Fe' Timing waveform
antthecat
Re: Hyundai Santa Fe' Timing waveform
Post by antthecat » Mon Jan 14, 2013 7:50 pm
Nice one, customers hey, always give you the information, it always depends on when though.
Hope its now easy for you buddy.
Ant
Avdr
Post by Avdr » Mon Jan 14, 2013 7:54 pm
antthecat wrote:Nice one, customers hey, always give you the information, it always depends on when though.
Ant
Aye, your MAFM theory may be bourne out yet if it turns out the valve timing is out...
Avdr
Post by Avdr » Mon Jan 21, 2013 7:49 pm
Got some time to look at the camshaft dowel pin issue today, and the reluctor issue on saturday. Both perfectly fine, pin has been replaced but its in no way unservicable.
Nodule on camshaft is also fine.
Have spoken to the original garage regards getting injectors bench tested. They might be able to borrow another santa fe.
Fingers crossed..
Avdr
Post by Avdr » Mon Feb 11, 2013 6:58 pm
Just to follow up,
Car was returned to the original garage, I wanted a proper injector test doing by an injector specialist. All has gone quiet, the last time I spoke to them, the injectors had not yet been tested. Owner was wanting to sell the car.
I also heard second hand that the first time it was rebuilt, the headgasket supplied was incorrect, and starved the head of oil. Apparently an overheat and seizure followed. Another something I wasn't made aware of.
alespreisler
Post by alespreisler » Sun Dec 16, 2018 11:50 pm
Hello, it´s an old topic, but it can help somebody. I had similar problem (maybe the same) on D4EA engine. It is the same as 2.2CRDi just 2.0CRDi. Realy excessive black smoke from idle, poor power when driving. Previous car owner had done some cylinder head repair. Compared to an another car when idle: Injection amount 11cubic mm istead of 5, exhaust gas temp 290 celsius instead 210, engine load 44 instead 27, lambda 2.5 instead 1.1. The timing side is okay, but scope shows that cam sensor is two teeth offside. Dissasembled and removed the head: the first camshaft bearing siezed and a new valve rocker fitted. I decided that there was a bad damage not repaired properly. Ordered new camshaft and compared to old one: the old one was 10 degrees twisted. Sent the head to specialized company for repair. After repaired head and the new camshaft fitted all values from ECU are good,black smoke disappeared and engine runs well.
alespreisler
Post by alespreisler » Mon Dec 17, 2018 11:43 pm
