Vauxhall 1.9cdti
crcoops
Vauxhall 1.9cdti
Post by crcoops » Thu Dec 20, 2012 9:18 pm
Hi just wondering if any one has come across a problem iv got, iv got fuel up to the high pressure pump but theres only a bit coming out of the outlet but not much pressure the customer has bought a second hand pump which has been tested but still the same problem. Just wondering we're to start with the scope? Iv got a 12v feed to the two pin plug on the pump could the fuel rail pressure sensor cause this problem?
Re: Vauxhall 1.9cdti
Post by Robski » Thu Dec 20, 2012 9:42 pm
Have you measured the LP to the pump or just guesstimating ?
What you got on the FRP sensor signal KOEO?
What's happening at the IMV, voltage/current-wise ?
It doesn't sound like you know a lot about CRD, have you replaced the pipes you have cracked off ?
How many channels you got ?
crcoops
Post by crcoops » Thu Dec 20, 2012 11:32 pm
Iv got 2 bar from the lp pump,iv got 0.65 then when cranking goes up to 300/400 on the frp. But what doesn't seem right is when I crack the pipe off there doesn't seem to be any thing there very little diesel.
Iv got a 2 channel ADC 212 which iv only just started using new to this just trying to learn as much as possible,info would be really helpful. I'm a novice who is trying to learn the hard way lol
On the injection quantity mg/stoke all 4 are 0.00
Also wont attempt on easy start which I would of thought valve timing was out but iv checked that and done compression test. But should still have fuel out of pump
Post by Robski » Thu Dec 20, 2012 11:43 pm
The HP pump delivers pressure not so much volume & you should not be cracking the pipe off to see !
What does your info system tell you about the LP ??
take 1 CH with cranking current & the other on the FRP signal, but it's no good telling you to post the capture as you never do which makes it difficult to try help.
What readings did a compression test reveal for each cylinder ?
& no attempt to start on sniff ??? is this the 150 ??
Milage ?
Do you have the 600 & low amps clamps ?
crcoops
Post by crcoops » Thu Dec 20, 2012 11:47 pm
Ill get a wireless dongle sorted for after Christmas if it helps more ill post my results.
