citroen c5 2lt hdi antipollution fault
pbmot
Post by pbmot » Thu Dec 06, 2012 6:37 pm
Citroen 54 plate 2lt hdi
Antipollution warning on and engine light on
comes up with mas fault
tested unit with scope tested ok within limits
slow acc on take off from standing start
wiped fault codes and ok next day light
on finaly replaced mas but still same
Re: citroen c5 2lt hdi antipollution fault
Post by Robski » Fri Dec 07, 2012 8:35 am
I think you will have to do a bit better !
What's the DTC ?
where's the capture ?
Avdr
Post by Avdr » Fri Dec 07, 2012 6:41 pm
did it run better for the new MAS (presume you mean MAF) being fitted?
