4423 PICO SCOPE
MIKEY62
4423 PICO SCOPE
Post by MIKEY62 » Wed Nov 28, 2012 6:42 pm
I really like my pico scope
Though I'm not thoughoughly adept with it, I have a question about using it with windows 7 service pack 1. My high and low current ramp probes will not adjust to "0" In cylinder pressure transducer doen't want to zero either. Whats going on with this thing????????????
Re: 4423 PICO SCOPE
Post by Alan » Fri Nov 30, 2012 5:12 am
This sounds odd, but its difficult to know whether the issue is with the setup, the probes or the scope.
Can I suggest the following - set the voltage range to say 1V and quite a long timebase such as 1 sec per division. With nothing connected to the channel check the voltage is at 0V.
Next connnect the low amps probe with probe well away from any cables carrying current, if its not at 0V then press the auto zero button when the trace has got to about 1 sec across the screen. You should see the voltage drop to 0V. Similarly for the pressure sensor make sure nothing is plugged in to the pressure port and switch the sensor on (assuming its a WPS500) it should then go through a calibration when it powers up.
If the above does not work then please post the PicoScope data files.
