CAN BUS test
Jabsam
CAN BUS test
Post by Jabsam »
Hi All.
Do you think this Can Bus signal is correct? Thanks.
Re: CAN BUS test
Post by Alan »
Not totally sure to be honest. CAN Low looks good - switching cleanly from approx 2.5V to 3.5V
CAH H is switching from about 1.3V to 2.3V so a little on the low side. The lack of high frequency content compared with the other channel makes me wonder if something is loading the signal a bit.
I dont think whatever is different with CAN H is enough though to cause any errors in communications.
Hopefully someone with more experience than me can comment further.
Darren Cotton
Re: CAN BUS test
Post by Darren Cotton »
First look seems OK, however, Can you post the psdata file please
What has made you check the CAN?
Darren
Jabsam
Re: CAN BUS test
Post by Jabsam »
The waveform is from a Buick car.
The CAN H & L look like normal. Sorry the picture in my post above, I activated filter on Ch B.
I most interest in why the one part of CAN H excessed 3.5 V (and one part of CAN L less than 1.5V). But while I disconnected the EBCM and VES, the CAN Bus swictched normally as standard(CAN H 2.5-3.5,CAN L 1.5-2.5).
Darren Cotton
Re: CAN BUS test
The peaks at the end I see as normal, end of data message... The reason when removing the nodes the CAN changes is maybe because the message data is not being transferred
I see nothing wrong with the CAN
Darren
Jabsam
Re: CAN BUS test
Post by Jabsam »
Hi Darren,
Thanks for your reply. Could you please explain that why the end of data message have peaks more than 3.5 Volt for CAN H & less than 1.5 Volt for 1.5 for CAN L?
Darren Cotton
Re: CAN BUS test
This is the acknowledgement section of the data frame. Its Normal.....
Darren
