Setting up Attenuators
Tristan
Post by Tristan »
Choosing 20:1 attenuator option on my channel automatically sets my range from -100 to 400v.but what if my voltage is reading more than 400v. how can i set up my scope to capture up to 1000vs/1kv with an attenuator. Or do i just choose +/- 1kv range with attenuator installed?
PicoMike
Re: Setting up Attenuators
Post by PicoMike »
In this case you can choose the x20 probe setting (rather than the 20:1 attenuator), this will provide you with a wider range of inputs.
HTH
Mike Valentine
Post by FioranoCars »
Sorry to ask a daft question ... but can you use 2 or more attenuators in Series?
ie use two 20:1 to achieve 400:1 attenuation?
thanks
Richard Lukins
Post by Alan »
Hi Richard,
BNC connectors and possibly the cables are not rated >400V so please do not cascade the attenuators as you risk damage to the scope and possibly yourself!
Direct measurement of high voltages requires differential isolating probes - we go up to 7000V with our TA042 but they are not cheap
http://accessories.picotech.com/active- ... html#TA042
Thanks, thought there might be a major issue with that!
I did think the attenuators were safe for ignition wiring etc, using clamp style HT leads, which will surely be in excess of 400v ?
thanks
Richard Lukins
Avdr
Post by Avdr »
FioranoCars wrote:Thanks, thought there might be a major issue with that!
thanks
The HT clamp on leads, convert the impluse they see into a suitable input voltage to the scope. You can see from the scope setup file in pico that probe is scaled y=10000x + c. Which in esscense means whatever the HT clamp inputs to the scope is multiplied by 10 000, so 1v input, is displayed as 10 kV.
