motorbike ignition fault
Re: motorbike ignition fault
Post by Robski » Sun Sep 30, 2012 11:10 am
Fat Freddy wrote:To me, it kind of looks like it's tracking to ground.
What colour are your plugs?
1&4 does but what about 2&3 ?
Post by Fat Freddy » Sun Sep 30, 2012 11:34 am
I think the same.
First kick on the Primary and nothing on the secondary.
tiggerbiker
Post by tiggerbiker » Sun Sep 30, 2012 11:52 am
here are the latest traces i have obtained - hope they are useful,
robski, your picture was very helpful - thanks
tiggerbiker
Post by tiggerbiker » Sun Sep 30, 2012 11:54 am
oops - heres the traces
bandit12 coil 2+3.psdata
(192.35 KiB) Downloaded 241 times
bandit12 coil 1+4.psdata
(202.87 KiB) Downloaded 237 times
ign. pickup + pri. amps.psdata
(1.88 MiB) Downloaded 252 times
Post by Robski » Sun Sep 30, 2012 1:30 pm
Fat Freddy wrote:I think the same.
Is it not correct that everything after the EMF kick (spark line) in the primary is a feedback of the secondary ? so why don't they match then if the secondary is shorting to ground(picture in previous post) (picture below of 1&4 which i agree looks like short to ground) ?
OP can you verify if you were coupled to the correct side of the coil secondary (+/-) as you don't seem to have changed probes & there is a strange sub zero voltage going on ?
tiggerbiker
Post by tiggerbiker » Sun Sep 30, 2012 1:36 pm
hi, yes i have connected to the correct feed.
Post by Robski » Sun Sep 30, 2012 8:29 pm
tb
Can you give us a heads up on how this ignition system works, how many wires to a coil pack, is there an ignition module etc ?
The last captures you have posted including the coil current have some crazy dwells going on & current amplitude, were both captured under the same conditions ?
The current ramps also look like there's a short with steep start to the up ramp & negative switch off characteristics & one is almost a square wave.
Where does the ignition pick up come from ?
Have you checked the resistance of the plug leads ?
Do you have an adjustable spark tester ?
PS pay attention to your sample rate, detail can be lost if zooming in when the sample interval is low.
tiggerbiker
Post by tiggerbiker » Sun Sep 30, 2012 8:41 pm
Robski wrote:tb
The current ramps also look like there's a short with steep start to the up ramp & negative switch off characteristics.
hi,
there is an ignition pickup on the end of the crankshaft which feeds to an ignitor module / ecu which then feeds 2 coil packs, each with a common positive feed and having an individual negative trigger.
the captures were taken within 1-2 mins of each other ( one of them i had the clamp facing the wrong way :oops: )
i do have a sparktester but its MIA at the moment - our tool van comes on wednesday so will buy another (no doubt i will find my old one on thursday!)
whats the best settings for running these kind of tests? - i have been using the built in automotive menu to do the setting up for me
thanks for your help and advice - its very much appreciated
ohh, found a wiring diagram online here: http://www.customfighters.com/forums/sh ... hp?t=46444
Post by Robski » Sun Sep 30, 2012 9:25 pm
Is the ignition pick up supposed to be a square wave ?
Check the power supply to the coils matches batt V( guessing they should be?) when cranking, check the supplies & grounds to the ignitor module.
Get your spark tester or a plug in the lead end & you be the ignitor module & ground the coil switched side with a test light from batt- quickly & release, the other side must be powered ie ign on or power probed, is the spark stronger ? (don't forget to ground the spark plug)
When I scope for ignition I set a sample rate for a 1µs sample interval.
Post by Fat Freddy » Mon Oct 01, 2012 12:29 pm
quote]
In theory, Yes.
But your second question disproves the first. For example if I grounded a plug lead would you expect to measure no induced voltage in the primary.
TBH I think this has more than one issue and I agree the dwell does not look right. Two long, two short - hows that fit with cylinder comps? Amp clamp?
