BNC extension leads.
mastertech02
Post by mastertech02 » Thu Sep 20, 2012 8:57 am
Hi All.
At present I am building a diagnostic cart and wish to install extended BNC cables From my Pico to bulkead connectors. I wish to use BNCto BNC extension cables.
My question is can I use readily available cables or is there spec required ?
Any Help please
Dennis Carey
Re: BNC extension leads.
Post by Alan » Fri Sep 21, 2012 10:36 am
Pretty much and BNC extension lead will be OK provided it has 50 ohm rather than 75 ohm connectors. One option is to visit our friends at AES Wave, they stoock quite a few eg http://www.aeswave.com/products/Product.asp?i=136&ci=55
mastertech02
Post by mastertech02 » Fri Sep 21, 2012 9:38 pm
Hi Alan.
Thanks for the info 50 ohm cables now on order.
Dennis.
joshua1
Post by joshua1 » Tue Sep 25, 2012 6:27 pm
will he face any issue if he uses 75ohm one. Is 50 ohm a standard convention
Post by Alan » Tue Sep 25, 2012 7:09 pm
At the sort of frequencies we are looking at (low by test equipment standards) the choice of cable (75 or 50 ohms) will make little difference.
50 ohm and 75 ohm BNC connectors have slightly different sizes for the center pin and there is a small risk of poor connection if different types are used.
