astra z16xep throttle body fault
Postby djautos » Fri Aug 17, 2012 10:09 pm
Hi all, we had a 53 plate 1.6 z16xep astra come in from another garage a few days ago, for a very bad starting and running fault. no fault codes. found throttle body motor on cranking forcing closed position, on half throttle car starts but if you let revs go below 2000 car die's. when running and holding pedal steady, engine revs up and down.accelerates up from 2000 - 5000 no prob, smoke tested for leaks, ( Non Found) Fuel pressure tested and and good. pedal scoped and is good. tps scoped and is good. on further investigation, disconected plug off throttle body and car starts and idle's great. found throttle motor to be bi directional. so scoped both feeds to motor, and on ignition ecu closing butterfly, with engine running and half down on pedal, ecu sending signal to throttle to open and close constantly. anyone any idea's.
will post pic of scope pattern of throttle body tomorrow
thanks
djautos
Re: astra z16xep throttle body fault
Postby Liteace » Sun Aug 19, 2012 2:17 pm
Can you get any live data, see what \ where the position of the TB is, also do an actuator test, check wiring to \ from ECU & also ECU earth, also try disconnecting the battery, reconnect, leave for a min, turn ignition on (dont start engine) leave for a min, then start (if it will start) and do another actuator test to see what the TB is doing
Liteace
Postby djautos » Sun Aug 19, 2012 2:40 pm
hi thanks for reply.
yea already done tb test and working fine, also done battery disconection and putting teminals together. but no change. cant understand why ecu is telling tb to close shut .
djautos
Postby Liteace » Sun Aug 19, 2012 2:44 pm
On idle does is it not using the idle control valve in TB with the butterfly closed
Liteace
Postby GRUSS » Sun Aug 19, 2012 3:59 pm
Very common for the throttle body failing on the Z16xep, done a few in my time.
GRUSS
Postby Robski » Sun Aug 19, 2012 5:27 pm
no fault codes
Read with what scanner ?
post the captures, at the moment 'good' is only on your word. Where did you pin-out ?
current & voltage or just one ?
Like Liteace has asked lets have some live data to go on,desired idle etc......
Below is the data from a few tests omitted from this forum but posted on another........
i have a astra z16xep on a 53 plate, come in to me from another garage with a starting/running fault. if i give half throttle the car will start, but not idle below 2000 revs or engine die's. on keeping half throttle, engine rev's up and down 2000-3000. so now you know what the car is doing i will tell you all the checks ive done. scaned (vaux com) no fault codes. smoke tested. found EGR leaking so fitted new, this then made engine fault worse, checked fuel pressure. 50PSI, happy with that. carried out compression test. 175. happy with that. unpluged throttle body, car started spot on and idled.1000 revs. on further checks to throttle body found ecu demanding throttle body to close , this is now obvious this is why it is had to start. loke i said on half throttle it does start. but watching throttle body it rapidly give WOT and cosed throttle . hense my 2000-3000 revs. scoped to see if throttle body fault, but found ecu demanding this. any suggestions.
Postby djautos » Sun Aug 19, 2012 9:07 pm
hi thanks for post , will post live data tomorrow but thought id give you a bit more info.
that other post that is same fault as mine . is my post on bba reman site, i am using xaux com and pico. there is no seperate idle control it is done by tb. the throttle body has its natural idle position, with the tb motor being bi directional. closed shut position and WOT. if i disconct multi plug on tb. engine starts great and idle's . multi plug , pluged in ECU close's tb. ta
djautos
Postby djautos » Mon Aug 20, 2012 10:42 pm
djautos
Postby djautos » Mon Aug 20, 2012 10:44 pm
djautos
Postby djautos » Mon Aug 20, 2012 11:03 pm
djautos
Next
