Help
glenn
Re: Help
Post by glenn » Sat Jul 07, 2012 1:04 pm
Liteace wrote:I think the front sensor most VW's is a wideband is it not, I may be wrong, please correct me if I am but I dont think you can use an oscilloscope for testing this type of sensor, Its always best to plug in a VCDS and do a readiness test or look at measuring blocks
Hi Liteace
We have the Launch431X and I went into measuring blocks but for some reason I couldn't Identify what it was reading usually it say's what your reading but not on this vehicle had something like 00001001? whatever that means, the only one I could Identify engine temp, no clues what the rest ment?
But I need to know why cant we read wideband with pico, thought the scope could measure any sensor, :?: think it's because I want to fix any vehice that comes in with the scope 8)
Glenn
Re: Help
Post by Robski » Sat Jul 07, 2012 1:54 pm
Bin bits............
Which could tell you info such as heater turned off or on, brake pedal depressed or not etc ............
Who said you can't :?:
glenn
Re: Help
Post by glenn » Sat Jul 07, 2012 5:18 pm
Which could tell you info such as heater turned off or on, brake pedal depressed or not etc ............This is fair enough, but couldn't work out which was the front lambda or rear?
So you can read wideband, I thought that was a weird statement :o
Cheers Robskil
Glenn
Re: Help
Post by Robski » Sat Jul 07, 2012 8:58 pm
This where you need a label file or tech info :wink:
