Peugeot 307 misfire cold.
hbr
Post by hbr » Thu Jun 21, 2012 8:20 pm
Hello here I am again with a problem car, a Peugeot 307 2.0 petrol with rfn engine from 2002.
This car misfires and backfires when you hit the throttle with a cold engine.
I have tested the fuel pressure, this is good, and I scoped the coil pack, this is where I need help.
The events don't look good to me but I don't know what the problem can be.
Peugeot 307 bobine.psdata
(3.15 MiB) Downloaded 412 times
Liteace
Re: Peugeot 307 misfire cold.
Post by Liteace » Fri Jun 22, 2012 12:13 am
Looking at that lot I would check 1st coil \ spark shorting to ground and then work from there
hbr
Post by hbr » Fri Jun 22, 2012 11:42 am
It has a coil pack on top of the plugs. Can it be faulty injectors? I found that one injector gets wet if you keep the pressure on the rail.
Avdr
Post by Avdr » Fri Jun 22, 2012 7:27 pm
CHB has nothing like the inductive kick that it should have compared to CHA. Would advise a coil pack.
See what others think...
Kev
Post by Kev » Fri Jun 22, 2012 8:50 pm
Hi hbr,
I would definitely replace the ignition coil pack on this vehicle, they don't last long on these systems. If you can, try to source a descent make otherwise you will have the same problem in the not too distant future. I must have replaced hundreds of these coils in recent years.
Regards Kev
PS would be handy if you could upload a known good waveform for this vehicle after you have replaced the coil!
hbr
Post by hbr » Fri Jun 22, 2012 9:02 pm
Hello guys, I will replace the coil pack and if its good I'll post a good waveform.
Post by Robski » Fri Jun 22, 2012 9:46 pm
Kev wrote:PS would be handy if you could upload a known good waveform for this vehicle after you have replaced the coil!
& crank the sample rate up a bit more.
jam670
Post by jam670 » Sat Jun 23, 2012 7:29 am
I have heard of non genuine spark plugs causing problems on some pugs. I don't know if it apply to this engine as well though but may be worth bearing in mind.
James
Post by Robski » Sat Jun 23, 2012 4:39 pm
What plugs are in this ?
hbr
Post by hbr » Mon Jun 25, 2012 6:48 pm
Bosch.
