Citroen C3 sensodrive
Liteace
Post by Liteace » Fri Apr 20, 2012 1:33 pm
Hi All, got here a 05 Citroen C3 with sensodrive, all forward gears OK, it will not go in reverse, when you select reverse you can hear it trying, after about 4 tries it gives up, Ive removed the sensodrive actuator from the top of the G\box just to make sure it will go into reverse when I select in manually. I do have wiring diag for the sensodrive system, is there anyway if I bolt it all back together I can check the actuator with me scope ?
Dan
Re: Citroen C3 sensodrive
Post by Dan » Tue Apr 24, 2012 9:24 am
Excuse the obvious - more curiosity:
Can you not trace the wires out?
If it's only accessible inside the gbox only:
I would run some thin wire (kynar or ribbon type) to the actuator wires and out - thin enough, but still careful that they don't get crushed & short to the casing.
That'll give me a connection for signal work, which I can scope from.
You may get to see the spikes from the actuators magnetic field collapsing (which is good - you know it's working in that sense).
I'd compare to other coils for similar spikes - which might tell you there's a short in the coil.
Knows pre-2000 Fords and R33's better than the back of my own hand.
Anything newer... I'm probably driving it :-(
