Doesn't display frequency when testing a digital MAF
GRUSS
Post by GRUSS » Wed Mar 14, 2012 6:23 pm
Watched Paul's video last night ( excellent :D ) so today thought I would try it out. I went through the usual preset and could see the frequency scale set on channel A in the notes but when I pressed the space bar to go live the scale was set on voltage (100v) tried looking for the frequency option in the AC/DC coupling option but can't find it... :(
Forgot to say... It's a 4000 series automotive scope with latest software on.
Re: Doesn't display frequency when testing a digital MAF
Post by Autonerdz » Wed Mar 14, 2012 7:23 pm
Gruss,
Sounds like the software was not communicating with the scope. You won't have the frequency select in the coupling dropdown unless the right scope is plugged in and communicating.
Just suggestion here though..
There is no reason I can think of why you would now ever want to graph frequency live. Why waste the channel? Use your channels to capture the MAF voltage and three other inputs. Then later, apply a frequency math channel to the desired channel. This can be done with a saved capture and the scope doesn't even have to be there. :wink:
Post by Alan » Wed Mar 14, 2012 9:09 pm
Tom's diagnosis sounds right - unless PicoScope detects a PicoScope 4000 series at start up then it will not enable the frequency measurement.
With the PS4000 you have the choice of measuring frequency either using a maths channel (which can also be done with the older PS3000 series) or to measure in hardware. The hardware method does give better resolution than the maths channel method, but both work. If using the maths channel make sure you have lots of memory enabled as this will improve the resolution.
As with the method of displaying frequency, whether you do it live or after capture is personal preference. I very rarely disagree with Tom but when doing a snap throttle test I like to see the waveform live to make sure I have captured it OK in real time. As so often there is no right or wrong so try both approaches and see which is best for you.
GRUSS
Post by GRUSS » Fri Mar 23, 2012 9:18 am
This was a error on my behalf. I have/had a bad habbit of starting the pico software before Connecting the scope. It doesn't seem to like it this way. Works fine if I connect the scope first though. I've learnt!
