4 channel kit on its way
Liteace
Post by Liteace » Sun Mar 04, 2012 4:57 pm
As you prob seen in the other post I have ordered the 4 chan kit, I must admit it will not be used that often but the main thing is it will be there when I do need it, I was reading this post:
http://www.picoauto.com/support/topic9086.html#p25143
The 1st thing Im going to probe is a 2003 Nissan\vauxhall\Renault Van 19dci, we dont really do that many diesels, this one a while ago stopped responding to any signal the APPS was sending to the ECU and drove like it had a 100cc engine in, no fault codes was showing and everything checked out ok, after a thorough loom check still everything checked out OK, I pulled the EGR off gave that a test and a good clean and now the van drives 90% better than it did when it had the fault but its still not 100%.
When me Pico gets here where do I start with this one ?
Liteace
Re: 4 channel kit on its way
Post by Liteace » Sun Mar 04, 2012 5:15 pm
edited
Post by Robski » Sun Mar 04, 2012 5:15 pm
has it got MAF or MAP sensor ?
Liteace
Post by Liteace » Sun Mar 04, 2012 5:18 pm
MAF for sure, Bosch EDC15,
I dont know what happend there in the other post, are we in a time machine, looks like I answered the question before you asked it !!!!!!!!!!!!
GRUSS
Post by GRUSS » Sun Mar 04, 2012 6:39 pm
Hello there
I've been involved with a chaps 2003 vauxhall vivaro 1.9 van last week. Basically he had been to several garages who couldnt fix the fault. No EM light on but would suffer from lack of power when setting off. It had no DTCS stored, a quick check of the live data fuel pressure, egr,boost and MAF. everything looked ok apart from a lazy MAF reading, it should of gone above 350 when revved but was only reaching 220. I checked the airfilter as these are common for been sucked in or blocked.. all ok. removed the EGR and checked that.. all ok
I then took a capture of the MAF which looked very low....
Yesterday i fitted a new siemens unit and retested.. the green trace is the new MAF
Took it for a run with the chap and he was over the moon! his van was finally fixed!
please feel free to use the attached files to compare with your suspect MAF :D
Russ
Vivaro 1.9 MAF before and after.psdata
(797.61 KiB) Downloaded 629 times
vivaro before.psdata
the original MAF under full throttle then let off
(384.47 KiB) Downloaded 602 times
Liteace
Post by Liteace » Sun Mar 04, 2012 6:41 pm
And did it drive any better after fitting new ?
GRUSS
Post by GRUSS » Sun Mar 04, 2012 6:48 pm
Hes had it since new and he said it felt like the day when he drove it home from the dealers... :D
Quick check of the live data and the new MAF was peaking at 360~kg/h when revved from idle
Liteace
Post by Liteace » Tue Apr 03, 2012 6:31 pm
Here's what I got today, engine idling then wot uptill rev limiter, about 4200 ish I think, it looks very low does it not
timo van.psdata
(394.83 KiB) Downloaded 599 times
GRUSS
Post by GRUSS » Tue Apr 03, 2012 8:09 pm
Liteace wrote:Here's what I got today, engine idling then wot uptill rev limiter, about 4200 ish I think, it looks very low does it not
timo van.psdata
Could you post a jpeg? I'm on my iPhone and won't have access to my laptop for a couple of days...
Infact use my green trace as a reference and over lay it with your capture.
Liteace
Post by Liteace » Tue Apr 03, 2012 8:19 pm
I'll post a jpeg in a mo, I'm on not so smart phone at mo as well, back to pc in about an hour
