V6.6.16.12 Hangs when trying to activate filtering
baging
Post by baging » Tue Feb 28, 2012 10:36 pm
Ok, small problem here....
PicoScope6 Automotive V6.6.16.12
PicoScope 4423
Driver version 1.1.0.204
HW version 1
FW version 1.0.5.0 / 0.6.12.0
Windows 7 /32
Freezes when trying to activate Lowpass Filtering
Immediatly on channel A and between 10-20 seconds on channel B.
With or without input on channels....
/Stefan
Re: V6.6.16.12 Hangs when trying to activate filtering
Post by Martyn » Wed Feb 29, 2012 9:38 am
We are aware of this issue and are currently testing a release of software that fixes it. This will be released to the webiste once testing has been completed.
In the mean time you may wish to try using "Resolution Enhancement" from the same channel drop down menu to clean up the signals rather than using the low pass filtering.
baging
Post by baging » Wed Feb 29, 2012 2:30 pm
Thanks. Will do that and good to hear you're on it :)
Post by Autonerdz » Wed Feb 29, 2012 4:33 pm
Stefan,
I am assuming you are applying the low pass filter live with the scope running? Have not seen this issue and was not able to duplicate it here but I see the Pico team is on it as usual. :D
We do not normally use the filter live at all but rather apply the filter to the capture after the fact. This way you do not compromise your sample rates and can dial in just the desired amount to clean up the capture. This may work better for you.
baging
Post by baging » Wed Feb 29, 2012 7:26 pm
Autonerdz wrote:Stefan,
Yes, your assumption is correct.... only time i've done it is live....
What you're suggesting is probably a better workflow, so i'll try that instead :)
Thank you! /Stefan
Post by Autonerdz » Thu Mar 01, 2012 12:19 am
Stefan,
Please let me know how that works out for you. Many do not realize that you can apply low pass filtering to a saved capture. This is a very powerful feature and has only recently become relatively stable. You may encounter some issues doing this with very large 'power user' captures. These often crash the application. Change the filtering level slowly or maybe type in the desired level so as not to have to chick over and over to get there. This tends to reduce the likelihood of a crash.
baging
Post by baging » Mon Mar 05, 2012 7:50 pm
Sorry, but i totally forgot about this one..... !!
Anyway, your advice works perfect.... no hangs or any other problem when using the filter on the capture!
Thanks again! :)
Post by Autonerdz » Mon Mar 05, 2012 7:57 pm
Thanks for the feedback. Glad we could help....
