Primary ignition testing
Liteace
Re: Primary ignition testing
Post by Liteace » Fri Jan 27, 2012 8:17 pm
Ive just scoped another DIS one on a Saxo and the other a Punto same sort of set-up the only difference being the Punto has got 2 seperate coils where the Saxo's are all moulded into one and im still only seeing 80 volts on the primary ??
Post by Robski » Fri Jan 27, 2012 8:48 pm
Is there a preset in your scope for primary ?
The ones i capture are through a 20:1 attenuator & a preset probe because the 4000 has a max input of 100V, what is the max input of your scope ?
I know on my Sykes Smart there is a preset for ignition as it is attenuated internally.
You should be seeing more than 80V on the primary kick .
Liteace
Post by Liteace » Fri Jan 27, 2012 9:09 pm
The scope has setting for primary and secondary & also has max voltage setting in scope and DMM of 400v, If i select primary I cant see nothing on screen, I have to go out of that setting go to scope and then select 125v, set the trigger then have a play with the time\volts untill I can see a good wave on screen, I'll a pic of the screen tmorrow
Post by Robski » Fri Jan 27, 2012 9:14 pm
Hmmmm :? no messing like that with the Pico 8)
Post by Robski » Sat Jan 28, 2012 10:02 am
Can you set a trigger at this point ?
And whats the max voltage in the scale ?
Liteace
Post by Liteace » Mon Jan 30, 2012 7:33 pm
Robski wrote:this's from an 07 Clio with DIS, a good example of zooming as well & also took 2 channels out leaving the one showing primary........
Go on you know you want to ............. :lol:
From just looking at that screen how could you tell if there is anything wrong ??
Post by Robski » Mon Jan 30, 2012 8:34 pm
Can you elaborate a bit more on that ?
Liteace
Post by Liteace » Mon Jan 30, 2012 9:14 pm
Well just looking at this screenshot without zooming in what does it tell you ??
SI picowave[1].png (355.66 KiB) Viewed 5057 times
Post by Robski » Mon Jan 30, 2012 10:35 pm
You tell me ??
There wasn't an issue with ignition on this car, the misfire was caused by something else.
Without being able to click on the picture you have attached & expand it its hard to see,the only thing i do see is turbulence in the cyl & a near enough straight burn line & an obvious switch to ground .
Do you see something else ?
