Picoscope6 software v6.6.16.12 doesnot detect picoscope6403
sudhansangeetha
Post by sudhansangeetha » Thu Jan 26, 2012 7:17 pm
Picoscope6 software v6.6.16.12 doesnot detect picoscope6403:
ps6000.dll - 1.0.0.248
Re: Picoscope6 software v6.6.16.12 doesnot detect picoscope6
Post by Martyn » Fri Jan 27, 2012 7:05 am
As you are on the Automotive Forum then I assume you mean Picoscope 6 Automotive. This will only detect Automotive scopes and as such will not find the 6403 which is a Test and Measurement device.
You need to use the standard Picoscope 6 software which you can download from http://www.picotech.com/picoscope-oscil ... tware.html
sudhansangeetha
Post by sudhansangeetha » Mon Jan 30, 2012 7:52 pm
thank you. i have tried with the same (PicoScope6_r6_6_16.exe) . but still the same problem.
My PC is recognizing the picoscope successfully but not the picoscope software:
ps6000OpenUnitProgress fails with handle = 0 which means that no device is found.
Any help is expected.
