PP836 WPS500X Pressure Transducer Kit
As part of Pico Technology's continuing efforts to expand our range of test accessories, we have now released the PP836 WPS500X Pressure Transducer Kit.
The kits comprimises of all the following Products:-
WPS500X pressure transducer
Carry case
USB cable
BNC to BNC cable
TA083: Fuel hose with large Schrader valve
TA117: Fuel hose with small Schrader valve
TA085: Vacuum hose
TA086: Bleed hose
TA087: Exhaust adapter
TA088: M14 high–strength compression hose
TA103: M10 high–strength compression hose
TA105: Ford Triton compression hose
TA129: Universal vacuum adapter
Although you can buy a WPS500X and accessories separately you can save money by purchasing the WPS500X Pressure Transducer Kit. The kit includes the WPS500X Automotive Pressure Transducer together with a large selection of hoses and adapters — everything you’re likely to need and at a reduced cost compared to buying everything separately.
