Vespa scooter ignition?
Postby minkey » Wed Jun 09, 2004 7:40 pm
Does anyone have experience using the capacitive pickup with two stroke magnetos with points (as in most older Vespa scooters)? No battery.
minkey
Postby ricardo » Thu Jun 10, 2004 12:05 pm
Thank you for your enquiry. I personally have never used a pickup lead on a scooters ignition system but I can't see why it would not work. If there is a high voltage going down the wire then the pickup should see it, its essentially a 10k:1 attenuator.
Best Regards,
Ric
Ricardo Paloschi
Sales Engineer
Forum Moderator
ricardo
vespa 90 scooter
Postby wkk427 » Sat Mar 03, 2007 3:13 pm
can any one give me any info on where the id numbers would be located and where to start troubleshooting the ignition i do not have a spark
wkk427
Postby davidj » Mon Mar 05, 2007 1:08 pm
You are much more likely to get answers about this on one of the sccoter forum such as this:
http://moped2.org/aspforum/display_forum.asp?fid=37
Good luck.
David
davidj
