Ford Focus 1.6 Zetec SE MAP signal
Re: Ford Focus 1.6 Zetec SE MAP signal
Postby Avdr » Wed Jan 18, 2012 7:29 pm
Be that as it may, do you have any info on the sensor?
Andy
Avdr
Postby Robski » Wed Jan 18, 2012 7:46 pm
Avdr wrote:Be that as it may, do you have any info on the sensor?
Andy
Not without the engine code, then it would only be the pin-out, then from the signal you get would be obvious whether it is analog or digital.
Postby Avdr » Wed Jan 18, 2012 8:06 pm
Fair enough, thanks for the interest.
All I've got here to go on is that the two wires into the ECU are pins 25 and 49,though I have no way of knowing which is responsible for which data, and its not certain that it's correct at all.
It identifies the system with MAP, as being 'Phase 3 &4 W/o HVAC'
Avdr
Postby Robski » Wed Jan 18, 2012 8:29 pm
49 = Signal in from MAP pin 4 MAP
25 = Signal in from IAT pin 2 MAP
This is not 100 % as no engine code.
Previous
