WPS Compression Hoses
antthecat
Re: WPS Compression Hoses
Post by antthecat » Wed Jan 02, 2013 10:13 pm
The normal m14 hose is fine for the zetec(yamaha or Mazda type), I've never had a problem yet.
Post by Robski » Wed Jan 02, 2013 10:29 pm
Buy the kit Damian i did.........
Just ordered the M12 comp hose today & that means apart from the M18 comp hose i have everything related to the WPS
Damian Mc Bride
Post by Damian Mc Bride » Wed Jan 02, 2013 11:07 pm
The reason i asked about the focus is went to do a compression test on one and the standard adaptor in my sealy kit wouldnt fit, the threads were not long enough.
Rob have you used the ford triton hose, what dose it fit.
Damian
Post by Robski » Wed Jan 02, 2013 11:30 pm
not yet mate, how do you mean not long enough ?
I've just measured the thread lengths from where they seal to the end :-
TA088 - 10mm - M14 X 1.25
TA103 - 12mm - M10 X 1.0
TA105 - 27mm - 0.6155" X close to 1.50 ( seems imperial )
Damian Mc Bride
Post by Damian Mc Bride » Thu Jan 03, 2013 8:27 am
Thanks Rob i just measured a few plugs most standard 14mm plugs have thread length of about 17mm.
The focus plug (NGK tr5a10) has a thread length 25mm, the TA088 wont reach the first thread inside head.
Is the TA105 14MMx1.25 thread.
Damian
Damian Mc Bride
Post by Damian Mc Bride » Thu Jan 03, 2013 8:31 am
Just noticed in description of TA088 M14 high–strength compression hose with adapter for deep reach spark plugs .
This is prob what i need.
Damian
Post by Robski » Thu Jan 03, 2013 9:55 am
Damian
I've updated previous post with thread sizes, but the TA 105 seems to be imperial, i don't have an imperial thread pitch gauge so i've gauged it very close to a metric pitch......
Damian Mc Bride
Post by Damian Mc Bride » Thu Jan 03, 2013 10:31 am
Thanks rob looks like its time to open the wallet :)
Damian
Post by Robski » Thu Jan 03, 2013 12:04 pm
Damian Mc Bride wrote:Thanks rob looks like its time to open the wallet :)
Damian
Good man you won't regret a bit of open wallet surgery 8)
Post by Fat Freddy » Fri Jan 04, 2013 12:05 am
The O'ring once rolled off will allow a collar to be removed allowing a longer thread. With collar removed you have 19mm less O'ring. :wink:
HTH
