easy setup
Alex
easy setup
Post by Alex » Tue Dec 03, 2002 9:02 am
i'm using the adc212, but your automotive demos are all recorded using a adc12? and i can't open it unless i change my setttings.
If the demos in future are saved for different machines like mine then when you open a saved picture then all the x & y settings and probe settings should be automatic be set to use
matthew
Post by matthew » Fri Dec 06, 2002 2:13 pm
Sorry to hear, that this seems to have caused problems for you.
This is unfortunately unavoidable, the demo data generation algorithm is designed to be used with the ADC-12. However, when you come to use the actual Automotive Software, all waveforms are recorded with the ADC-212.
I will pass on your comments to the software team as they will probably help to make our demos more useable in future.
Best Regards,
Matt Everett
Pico Software Engineer
