4423 or 4424 What's the difference?
Tech_6
Post by Tech_6 » Fri Jun 10, 2011 7:32 pm
Anyone have an idea what is the difference between the 4423 and 4424 USB scope?
Lee
Re: 4423 or 4424 What's the difference?
Post by Lee » Sat Jun 11, 2011 9:59 am
Dear Sir/Madam
Welcome to our Forum and thank you for your Post.
In regards to your question there technically is no difference between the 4423 and the 4424 Scope as a unit. They are both more than capable of being used with Electronics of any description with the correct accessories.
The key differences are however that the 4424 series scope will not run in Automotive PicoScope, Motorcycle and Pico Diagnostics. In order to run this software you would require one of the following scopes: -
• 4423 – 4 Channel Automotive Scope 4000 Series
• 4223 – 2 Channel Automotive Scope 4000 Series
The Automotive Scope will also run in Standard PicoScope 6 so you could use it as a normal lab scope should you wish too.
Alongside this an important change to this type of Scope is that the warranty on all automotive scopes is 2 years as opposed to 5 years. This is due to the scope being used obviously in more dangerous, less protected and harsher environments.
You would defiantly benefit from using the Automotive Software as it makes the 4423 an ‘Extremely Powerful Diagnostic Device’ as the software is configured with a comprehensive list of ‘Automotive Tests’ and ‘Help Files’ to make even the most difficult test to configure ‘easy and simple’.
It’s just as important to note should you wish to use other software like the ACE Misfire Diagnostic Software then again only the, 4xx3 scopes will operate and not the 4xx4 Series Scopes.
The 4424/4224 would be useless to you as an Automotive Diagnostic Tool.
I have included the following links to allow you to look into our Automotive Section and equipment.
Automotive Scopes, Leads and Testing
Automotive Accessories http://www.picoauto.com/automotive-accessories.html
For Can Testing, CAN Test Box (PP619) http://www.picoauto.com/can-test-box.html
For Specific Automotive Kits http://www.picoauto.com/automotive-kit.html
Automotive Software (Available FREE & in DEMO mode) http://www.picoauto.com/software.html
I hope this helps to answer your question and if you have any further questions then don’t hesitate to get in touch with us.
Kind Regards
Lee – Automotive Technical Specialist :D
Tech_6
Post by Tech_6 » Tue Jun 14, 2011 4:47 am
Ok.....
So if I understand correctly, the 4423 has the same capability as the 4424? Does that mean I can run it as non-automotive? Or does really make any difference?
The reason I ask, is cuz I do the majority of the diagnostics in our shop now with a Snap-On Modis and with my personaly owned AutoEnginuity. But I also do custom machining, electronic designing and building at home as a hobby.
The CRT labscope I have now is ok but just doesn't do for me what I need anymore. Am after an informed direction to obtain abilities in both areas of interest.
Lee
Post by Lee » Tue Jun 14, 2011 10:49 am
Yes you can run the 4423 as a Lab Scope in the Standard PicoScope software as well as an Automotive Scope in conjunction with the Automotive Software.
For your applications of use, you could run the Automotive software at work and should you need to, you could run the Standard software at Home. The Key only difference in the Software is that the Automotive software has a built in library for Automotive Testing and the standard software does not. Therefore you could even use the Automotive Software for the projects you do at home and just ignore the 'Automotive Tab'.
Kind Regards
Tech_6
Post by Tech_6 » Tue Jun 14, 2011 3:55 pm
Perfect!
Thank you very much!
