1981 924 Porsche Turbo-crank sensor
ultratune
Post by ultratune » Mon May 23, 2011 6:06 am
Help -can any one tell what type of crank sensor is fitted to a 1981 924 turbo Porsche - it has 3 wires it could be inductive or hall effect - help??? how can i tell - the confusing part is i have 6v coming from the ecu - but should i be getting any voltage with an inductive sensor with the 3rd wire being coaxil shielding -very confusing-p.s sensors appear to no longer available anywhere in the world hence the search for an alternative but i need to know what type of sensor im dealing with-thanks if anyone can help....
mecanic
Re: 1981 924 Porsche Turbo-crank sensor
Post by mecanic » Mon Nov 05, 2012 11:58 am
Back probe the signal wire and the pattern will tell you instantly what it is. :D
Liteace
Post by Liteace » Tue Nov 06, 2012 12:38 am
1st post Mon May 23, 2011, Im sure he would have got it sorted by now !!!!
:D
